Sub + Amplifier
Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 1
Hi Guys,
Looking if its possible to install an amplifier plus Bass sub to standard head unit for back of Van 2017 B9, i have an old sub box kicking about and thought i'll put in van to boost the sound so hence the question ?
Many thanks in advance
Threads: 5
Thanks Given: 1
(09-09-2022, 06:32 PM)Superpie747 Wrote: Hi Guys,
So what I'm looking for is a wiring diagram as to if possible where I'll connect up Amp to reverse of my stock 7" Tablet touch screen Head unit.
Any Help would be hugely appreciated
Threads: 75
Thanks Given: 223
164
Here's the pinout, but you'd have to cut and splice wiring into the rear outs, as there are no sockets for sub connection.
pinoutguide.com-Citroen Quadlock RD4 Head Unit connector pinout.pdf (Size: 95.4 KB / Downloads: 48)
Threads: 5
Thanks Given: 1
(10-09-2022, 08:40 AM)Zion Wrote: Here's the pinout, but you'd have to cut and splice wiring into the rear outs, as there are no sockets for sub connection.
Brilliant and a big thank you i'll get straight on it.
Threads: 5
Thanks Given: 1
17-09-2022, 03:46 AM
(This post was last modified: 17-09-2022, 04:01 AM by Superpie747.)
Hi Zion
Sorry for late reply, I have now got all my fixing kit for Amplifier etc but before I go ahead on splicing into harness and fitting amp I just wanted to ask if you know which wires I connect my RCA's to ??
I'm looking at diagram you kindly sent me and have worked out where my Remote out goes to for amplifier power on off but not sure about the signal input options (RCA's) or Rear outs,
Any help would be greatly appreciated
Threads: 75
Thanks Given: 223
164
18-09-2022, 10:48 AM
(This post was last modified: 18-09-2022, 10:55 AM by Sol.)
I would wire the sub into the rear set, left + right since you probably don't have rear speakers (maybe in the car but not the van) and even if you do, I'd parallel them onto the rears, so the input level can be controlled by the front / rear bias.
If it's a mono sub, then just hook it up to the left rear + & - with the plus to the centre pin of the RCA socket and the - to the shell. Same goes for stereo.
Threads: 5
Thanks Given: 1
(18-09-2022, 10:48 AM)Zion Wrote: I would wire the sub into the rear set, left + right since you probably don't have rear speakers (maybe in the car but not the van) and even if you do, I'd parallel them onto the rears, so the input level can be controlled by the front / rear bias.
Many thanks Zion all done and dusted.
Power cable webt through Firewall for bonnet cable and all the instructions and wiring diagram you posted all worked a treat. Nice little instillation made easier.
Threads: 75
Thanks Given: 223
164
Great stuff!
Threads: 22
Thanks Received: 49 in 45 posts
Thanks Given: 40
4
(19-09-2022, 03:19 PM)Superpie747 Wrote: (18-09-2022, 10:48 AM)Zion Wrote: I would wire the sub into the rear set, left + right since you probably don't have rear speakers (maybe in the car but not the van) and even if you do, I'd parallel them onto the rears, so the input level can be controlled by the front / rear bias.
Hello!
How did you passed the power cable from the battery to inside/dash? I need to install an amp inside dash but no ideea where to pass the cable through firewall..
If you like gaming visit GameForest
Threads: 75
Thanks Given: 223
164
(11-10-2022, 12:42 PM)deejay_xb Wrote: Hello!
Looks like he used the grommet that passes the bonnet pull cable through the firewall, to pass the power cable through.
Yet another ABS fault
Today 10:56 AM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
