Side door & interior lights
I’ve got a 15 plate, when I open the side door the interior light to the rear doesn’t come on.
I’ve also noticed that when the door is opened it doesn’t show as open on the dash.
The central locking works tho.
Has anyone had similar issues???
Well you would think that the switch to turn on interior light would be the same thing that activates the door open warning. Maybe needs replacing. Should be able to connect wires together on the back of the switch and see if light comes on?
It's a single wire, when grounded it signals the BSI that the door is open. One terminal of the switch goes directly to earth.
Is there a contact plate or switch on the door that will activate?
I'm pretty certain there is no external switch like you'd expect to find, it's built into the door lock / latch mechanism. (On the door itself, not the frame.)
(11-09-2022, 08:36 PM)Zion Wrote:  I'm pretty certain there is no external switch like you'd expect to find, it's built into the door lock / latch mechanism. (On the door itself, not the frame.)
Just thinking. The remote locking works so I would presume this should activate the lights when the door opens? Should there be a latch or something on the handle.
Open a front door, roll the latch (flick it closed as if the door was shut, using a screwdriver) - wait for the lights to go out, then pull the handle to unlatch the door (which is still open) - the front interior lights will go on.
I've attached the schematics for passenger lighting, 1 & 2 & 3. The contacts are definitely in the lock mechanisms on the doors themselves. They connect to the BSI and also the lighting units. 6202 is the RHS door for example. The BSi turns the lights on when the door signals it is open, subject to the ECO mode timer not expiring.
.pdf   B9_Interior_Lighting.pdf (Size: 158.15 KB / Downloads: 15)
.pdf   B9_Interior_Lighting_2.pdf (Size: 80.39 KB / Downloads: 12)
.pdf   B9_Interior_Lighting_3.pdf (Size: 269.31 KB / Downloads: 11)
.pdf   wiring legende.pdf (Size: 73.44 KB / Downloads: 11)
Hi,
I want to add some LED strip lights in my load area. Can I connect them to the back of my courtesy light?
I popped the light out and can see 1 plug plugged into the back of it with spare ports available for plugs. Can I connect to one of these ports with the red and black lighting wire?
Ian.
Attached Files Thumbnail(s)
You'll have to follow the diagrams above and decide.
All lighting is controlled and powered from the BSI.
I connected my front camera monitor to the map light bulb terminals and the BSI powers it all the time now when the ignition is on. This also caused the bulb to be lit constantly, which got hot so I pulled the bulb.
Be aware the BSI will do weird things when you connect up LEDs. Multiplexer lighting systems are not like old school car lighting.
  • IanM
triangle light
Yesterday 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
Fuel pump problems
02-06-2026 07:07 PM
