Threads: 10
Thanks Given: 8
I have a '22 Berlingo 1.5 HDI, and it does activate cornering light, and no option on Infotainment.
Anyone knows if this require activation from dealers?
Or it depends on models?
Thank you.
Threads: 11
Thanks Received: 31 in 31 posts
Thanks Given: 3
7
Not sure what you are asking for. You say the cornering lights work, so do you want to disable them? If so why?
Geoff
Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
15-09-2022, 11:52 PM
(This post was last modified: 15-09-2022, 11:52 PM by Matt Haigh.
Edit Reason: grammar
My cornering lights operate, I believe I have seen an option to turn the function off in the vehicle options on the touch screen
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
What are cornering lights?
Now a 2019 K9 1.2 petrol.
Threads: 11
Thanks Given: 3
7
They are in with or are actually front fog lamps. When cornering at night they turn in unison with the steering wheel to illuminate the ground ahead and to the side.
I find they pick up things you could miss when turning tight, say into a driveway or similar.
Geoff
Threads: 19
Thanks Given: 12
16
Well, you learn something new every day. I remember years and years ago Citroen tried that with headlamps. It seems they've brought a variation of it back. I wonder if I have them then.
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
the skoda octavia has a system that lights up the fog light right or left when below a certain speed and the steering is turned as as a road junction. The lamp itself does not turn, it just turns on the bulb.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 75
Thanks Given: 223
164
(16-09-2022, 12:37 PM)brodfather11 Wrote: the skoda octavia has a system that lights up the fog light right or left when below a certain speed and the steering is turned as as a road junction. The lamp itself does not turn, it just turns on the bulb.
That's my experience of cornering lights, it just alerts other drivers to the angle you have turned the wheel by lighting up the fog on the side you are turning towards. Adaptive headlights, which is what turns to point in the direction of travel, not the same as cornering fogs.
Threads: 39
Thanks Received: 4 in 4 posts
Thanks Given: 21
Can it be activated on earlier models ie just a software switch?
2021 Berlingo Flair M (K9) 130D
I.T. is there to help, but unforgiving if you make a mistake
