[Steering & Suspension] Power Steering Faulty - 2014 1.6 Diesel Auto
Hi fellow Berlingo Owners,
I am brand new to the forum and hoping that some of you knowledgeable folks will be able to help me out.
My problem is to do with the steering, all was fine and well when i set off on my journey to visit a friend
(less than a 10 minute drive)
I was only there for a 5 minute chat before setting off on the return journey home, less than a minute into driving back the steering became very stiff, the warning light lit up and the message "Power Steering Fault" appeared on the LCD display.
The car was driveable but with no power assisted steering all the way back.
When i arrived home and tried the car again to see if the fault had remained or was just a glitch the steering wheel had a quite strong judder/vibration to it.
I have checked the power steering fluid level and topped it up.
The fault warning however remains, have any of you suffered from the same issue or have any helpful knowledge?
Thank you in advance for any advice.
James
Have you checked the belt condition/tension?
Not sure how relevant my experience is. Have had tightness and juddering on steering. Not sure what causes it. After some investigation I tried raising the car so front wheels are of the ground . Winding the steering from lock to lock 6 times or so which is suppose to reset it . Seemed to work . Steering went smooth again. Never had a fault come up. Why yours failed with nothing to explain why it happened I don’t know. I hit a kerb which caused it the first time. Every time I get and MOT it does it. Assume it’s because the tester is using a prybar to check for play which seems to upset it.
It has electrical power steering,check for fuses first,then visit workshop.
BSI
Last Post: Zion
Yesterday 06:47 PM
» Replies: 26
Dropped a valve ?
Last Post: james1089
Yesterday 05:34 PM
» Replies: 24
HELPPPPPPP, citroen extended warranty team rejec...
Yesterday 05:20 PM
Add blue / engine fault light
Yesterday 05:13 PM
Newbie
Last Post: Rosemerry
Yesterday 02:48 PM
Electric probs - where to start
Last Post: Zion
Yesterday 10:58 AM
Replacing wings
Yesterday 10:01 AM
Sliding door rattle
Last Post: melpa
Yesterday 12:57 AM
New to Berlingos - Impressed so far!
Last Post: RichCowell
29-09-2023 11:03 AM
Appropriate Jumper Battery
Last Post: Abaddon
29-09-2023 09:38 AM
