Power Steering Fluid
My Haynes manual tells me I need Total AT42 fluid for my 2010 Berlingo with its belt driven drive assembly. I can’t find this anywhere near me. Is there an equivalent I can use, does it need to be synthetic etc. I have a Halfords round the corner but it’s no good asking them!!
2010 Berlingo Multispace 1.6HDi - Chipped
Dexron III was the original replacement for Total, and this was later upped to Dexron VI (which can be used but exceeds the original spec)
However good old Halfords own brand -https://www.halfords.ie/motoring/engine-oils-fluids/gearbox-oil/halfords-transmission-and-power-steering-fluid-1l-262407.html  - is equivalent to Dexron III
  • old son
Excellent, thank you for this information.
20-07-2026 02:51 PM
Clocks dropping out
Last Post: Micklew
18-07-2026 09:29 PM
air con
Last Post: magoo1
18-07-2026 04:56 PM
triangle light
Last Post: Buki
18-07-2026 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
