Front Wipers Not Wiping
2011 Berlingo First 1.6 HDI
Front wipers not working. Stopped working while driving, not the first time they stop working. Everything else seems to work.
When wipers worked we parked the car for a month and forgot to disconnect the battery. It was completely flat after a month so we recharged and connected it back. Wipers didn't work anymore. Parked for a month with battery disconnected, connected the battery and wipers worked! While driving wipers stopped wiping and parked. Wipers either worked or didn't, no weird activity ever.
Since they parked exactly where they're supposed to be (I have it marked on the windshield) I assume the motor, parking switch, fuses and relays are good. Relays are not clicking. Reset procedures found on youtube do not seem to help.
Are Haynes wiring diagrams correct? It shows 11Gr connector at steering wheel switches in Wash/wipe diagram so it should be like an 11 pin grey connector? Where's that? I only recall 6 pin grey and brown connectors.
I've read that on some cars wipers get disabled when bonnet is up. I think the switch is disconnected or whatever that was, not sure where the cable is but can bonnet switch disable wipers on berlingo?
Here is the official Citroen schematic along with connector locations.
.pdf   M59_Wash_Wipe.pdf (Size: 702.48 KB / Downloads: 28)
5015: Windscreen wiper motor
1620: Vehicle speed sensor
1320: Engine ECU
5100: Windscreen wash pump
CV00: Controls under the steering wheel
PSF1: Engine bay fuse box
BSI1: Multiplexer
CV00 is a 6 pin grey connector. (6V NR = 6 pin GRey)
Colour codes:
.pdf   wiring legende.pdf (Size: 73.44 KB / Downloads: 10)
  • SinsBird
Thank you. I wanted to check if a signal is coming from controls, but I guess I will simply solve the problem with a good ol' wipers relay.
Yeah the problem you have is the controls go to the BSI and it then in turn, operates the wiper motor. That rules out chucking a relay in unless you want to get creative with separate switch wiring.
What I would say to check, is pull the fuses in the main engine bay box and check the tags are clean & bright, another member on the forum had a nightmare getting something to work and it turned out the fuse blades were oxidized, and all needed cleaning, at which point everything worked again.
The could explain it not working after sitting for a while, and maybe a jolt caused it to work again, and then oxide took over. Low voltage connections are plagued by connectivity and oxidized pins.
I noticed in the circuit diagram that the coils of the wiper relays are connected in series so if the first coil is not making contact, the second relay also won't work. I think I will split the BSM to see what's inside, test the relays.
Since the provided wiring diagrams differ from haynes I decided to test a spare wiper motor with a multimeter. Turns out haynes is correct and the other diagram is wrong O.o Park signal wire is being pulled straight to ground through the parking switch.
Rear light cluster removal
Last Post: phydaux
Yesterday 11:47 AM
Cranks but won't start
Last Post: MarkA67
Yesterday 10:45 AM
Last Post: BrianS
Yesterday 10:35 AM
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
17-11-2025 10:07 PM
Engine Fan Running
17-11-2025 09:59 PM
Bettery Issues - A Solution.
17-11-2025 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
