Hello all.
My trusty Berlingo failed the CT today (French MOT) as it was dripping fuel on the testers nice clean floor. After a return home and many hours stripping bits off and cleaning and looking I found that the cold start thingy on top of the fuel pump was the reason. I can only presume that when connected and under spring tension the shaft that goes into the fuel pump has just enough force on it so that fuel can seep out ..up and then down and away!
Well, I stripped the mechanism off and without all the bits there and the shaft left alone it does not leak at all. The car works well it just needs a few seconds on the throttle at start until a tiny bit warm or it stalls.......But is no longer leaks and cost nothing.
First picture is the mechanism before. I stripped it out, you can see the fuel seeping out under it. The second is the post it all sits on that turns as the engine heats (This is how it is now, after a test run there is no fuel seepage any more.) and the third are the bits.
It's a 2001 1.9d with 322,500 k on the clock.
