Fault codes popped up after engine management light coming on
Hi all so Van went haywire today engine management came on then urea and triangle with exclamation mark in centre of it also 700 miles till no start warning..
Plugged a fault reader in and came up with:
P20F6
P20EE Stored
P208E Pending
P20EE Pending
Anyone any ideas ??
There was a slight bit of blueish white smoke from exhaust and a slight bit from under bonnet.
Berlingo 1.6 Blue Hdi 100, 2017 55000 miles on clock
Hi there.
There are no codes in the official documentation with letters in them, no idea what your code reader is pulling those from. All P codes are engine related and all only contain numbers.
P20xx all relate to cat & emissions, but with the Urea light being on, normally you are low or out of Adblue. Try sticking 5L of the magic juice in.
It's possible the Adblue pump / injector has left the building...or there is a problem with the Eolys pouch / pump / injector - best idea, get it scanned with proper Citroen software (DiagBox) as a generic code reader is next to useless on these vehicles. I would try the Adblue top up first though, before trying the dramatic options.
These codes are more likely (original OEM data) and are the only 3 codes starting P20
P2031
Temperature downstream of catalytic converter signal : Implausible temperature before starting the engine
P2032
Temperature downstream of catalytic converter signal : Short-circuit to earth, or value too low
P2033
Temperature downstream of catalytic converter signal : Short-circuit to positive, open circuit, or value too high
I've attached the official code list for the 1.6 HDi engine below: (for EDC16 ECU but the EDC17 you have will not be much different)
.pdf   B9 HDi Engine Codes.pdf (Size: 565.89 KB / Downloads: 15)
  • Pedronicus
One thing after another
Yesterday 09:01 PM
12-11-2026 10:41 AM
» Replies: 16
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
