gearstick
Hi all ,i have 1.9d berlingo forte 2003 model, can anyone explain how to remove the gearstick ?? I am trying to solve the floppyness ?? there is no play in the three rods up front ,little play on the main rod coming from gearstick to ball joint up front ,so i am thinking the play might be with the gearstick itself, been under car but cant see any nuts or anything holding it there !!.i removed gearstick gaiter and i can see four studs there but nothing there to put a spanner to ,help needed ,thanks in advance GWYN ??
Big Grin nice to be important,more important to be nice Wink
my ride is a  berlingo forte 1.9d 2003 model in pukey blue  Huh
The gear stick assembly drops downwards after the odd shaped 'domed' nuts (look like 10mm or smaller) are removed with a deep socket or box spanner from the long studs that you can see.
Pics messing around!
Thanks my mucker, will i be able to take apart to see if the gearstick pivotal mechanism is worn ??as you can tell from my questions i am not very mechanically minded ,
I have a feeling that the 'ball' section at the bottom of the lever may not come to pieces, but at least you'll be able to feel how much play there is and to decide whether a replacement is worthwhile. Maybe try searching for a repair kit or a replacement lever assembly.
Thank you my mucker i am very much obliged to you ??
I have solved this problem now !!!! Thank you all for your input
Good to hear mate, what did you eventually do?
Hi Zion you ok ?? ,well as i stated i am not very technically minded ,im a monkey see monkey do sort of person,so i dont know if you will understand what i put in writing !!here goes ,drove car up on ramps,got under car by gearstick ,there was a lot play on the headless bolt that held it to the main gearshift rod,undid the nut holding them together,had to hammer the mainshaft off the stud,couldn't remove the stud ,but thats where all the play was,there was some sort of non meral sleeve on the threaded stud ,so i put an eighth width washer on first ,put some grease on the stud and slid it back on to the main shaft ,out a narrower washer on then a spring washer and tightened it back up and its good as new,and being i am 75 years old i am very pleased with myself , hope you've uhderstood what ive written , Gwyn
I get it Gwyn, sounds like you did a good job mate, not so easy crawling about under a car these days for me either so I admire your getting on with it at 75! Well done.
If I have to lay on the ground for hours fixing stuff, I hurt a wee bit for days afterwards.
Yesterday 07:51 AM
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
