CAN BUS Wiring diagrams
Hi.
I wonder if you can help me. My mate has problem with starting his berlingo. After plug it on I can't see engine module but I still have access to airbag and abs modules. I suspected either faulty module or wiring issues. Is there any chance you could provide me with wiring diagrams please?
WIN NO is VF7GB9HWC94346257
Any help would be much appreciated ?
Thank you very much in advance
I've attached what I think are the most useful diagrams. This could be due to a lot of things, immobiliser in the BSI, ECU fault, fuses, especially the big Masterfuses under the engine bay fusebox top level, fuel pressure, HP pump, and what you can connect to will depend on the diagnostic unit you have. Generic ones do not work well at all on these vehicles.
I can't search by VIN, if you want that level, you'll have to buy a subscription to ServiceBox online. I have the offline version so can only search by model.. I'm assuming your mates vehicle is a 1.6HDi, if not, I have nothing here I can send that will help.
.pdf   BERLINGO (B9) - D6AY012LP0 - Help in diagnosis _ Starting problem - Engine DV6 (BOSCH ECDc16C34) (Summary).PDF (Size: 72.55 KB / Downloads: 68)
.pdf   Injection ECU.pdf (Size: 104.45 KB / Downloads: 58)
.pdf   Engine.pdf (Size: 191.77 KB / Downloads: 49)
.pdf   Electronic Injection.pdf (Size: 509.26 KB / Downloads: 50)
.pdf   Engine Start.pdf (Size: 127.47 KB / Downloads: 40)
Wiring colour guide:
.pdf   wiring legende.pdf (Size: 73.44 KB / Downloads: 63)
And read through the how-to section at the top in pink, I posted lots of info there. Link below:
https://www.berlingoforum.com/forum-12.html
(01-10-2022, 05:36 PM)Zion Wrote:  Wiring colour guide:
Thank you very much. He has 1.6hdi so your info should be spot on. It seems that you covered all aspects there. I have only genuine code reader but so far never had a problem before that's why I think it will be some broken wire somewhere. I know it will be time consuming hence a lot of garages just sent him away Confused
Thank you very much again I really appreciate your time.
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
