Clutch
How much should I expect to pay for a clutch ? Also is there a heavy duty option as I tow a caravan ?
Maybe there is an aftermarket HD option but the standard clutch is the same unit on all models. I got mine done last year and was quote £1400 fitted from all the local trusted garages (there's a fair bit of labour involved on these) - I ended up using a "Mr Clutch" type of outlet for £400 but the job was not as good as I would have liked, they damaged the wheel arch and did not fill the gearbox back up with oil, so 6 months later, it started to whine and was found to be low in oil, with no visible leak.
Thanks for info Zion....£1400...ouch
Believe me, I almost fainted.
That's up in sunny Scotland, you may get a better deal round your way but I'd do a bit of phoning around for prices, and then see if any friends can recommend a good garage that is trustworthy. Then the quote they give should provide a baseline.
I tried three well-known and trusted local shops, they all said the same thing. But, they were also busy and couldn't fit me in quickly, the good shops usually are booked up. I found a wee clutch place that only does clutches, one man band kind of place. I should have known better but was desperate.
Used the indy that I trust £394 all in, no dpf ..
2009 1.6HDI with AC
Might be the rates are better where you are, I'd happily have paid £394 with a good garage. All my local ones charge £60 an hour and upwards. City centre rates I guess.
I thought Citroen do a fixed price clutch repair from dealers.
Here is an example of a price of 'from' £399
https://www.desiragroup.com/citroen/serv...e-repairs/
That's very interesting and good to know. Mine is in for mot at main dealer next week so I will ask the question ?
Yesterday 03:36 PM
Last Post: JPCoetzee
Yesterday 10:34 AM
13-03-2026 09:14 PM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
