Threads: 2
Thanks Received: 1 in 1 posts
Thanks Given: 1
When I start the engine after a short drive and a short rest my batterylight stays on for 10 to 30 seconds too long. Long enough to give me the warning beeps.
This never happens on cold starts, and not after long drives either it seems.
Anyone else have had this experience?
Threads: 11
Thanks Received: 4 in 3 posts
have you checked to see if the alternator belt is slack
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
Hi,
Your alternator has to have a votltage regulator, if it did'nt it would boil your battery. It sets the max output to approx 14.4 volts. All alternators make AC. current, Thus the word Alternator, which when passed throught the rectifing circuits Diodes which are built in to the alternator , to DC voltage which is used to charge batteries etc. This can take a lot of effort to turn.(Torque) Your problem may be the drive belt which may be slightly loose which when cold is tight and due to friction heats up quicker than the engine. Ford had this problem on the early 1.8 d escorts, the belts /pulleys on the engine and alternator had three ribs and the belts felt tight but did an awful squealing (think slipping) until after they warmed up. The belts and pulleys were changed to 5 ribs and cured the problem.
