Gearbox Breather
Hello
I've just bought a 2004 1.9d Berlingo van. I've been working on the engine and have found its missing its gearbox breather. There is just a broken plastic union sticking out of the top if the box. I can't seem to find any mention of it in the manual or on the Internet. Can anyone supply me with a photo of what I need to get for it. I assume it's a reasonable sized pipe as the is a plastic pipe clip located next to the broken Union in the gearbox. I could do with finding out where the other end of the pipe fit into aswell. Thanks for any advice in advance.
The gearbox breather is located at the top of the gearbox casting and is a screwed in unit with a 'floating' plastic cap which allows any pressure to escape and stops muck going in. There is no pipe attached. If you just have the screwed in part with no lid then put a folded over pipe-cleaner into the hole and this will achieve the same.
(07-10-2022, 01:05 PM)oilyrag Wrote:  The gearbox breather is located at the top of the gearbox casting and is a screwed in unit with a 'floating' plastic cap which allows any pressure to escape and stops muck going in. There is no pipe attached. If you just have the screwed in part with no lid then put a folded over pipe-cleaner into the hole and this will achieve the same.
Oh right okay thanks.
2011 B9 DPF warning light
Today 02:22 PM
Today 10:53 AM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
