Threads: 8
Thanks Received: 1 in 1 posts
Thanks Given: 8
With the arrival of the damp weather it seems my driver side window has become intermittent in operation.
Is the "green" relay I've read about a good place to start?
Are they the sort that can be taken apart to re-solder the joints as in certain other makes like Skoda/VW?
Is there any other "common" failure point similar in nature to the BSI relay failure of the central locking relay, but for the drivers window?
Many thinks for your received wisdom.
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
The windows will be controlled by the BSI in the same way as the central locking is.
If it is one window only, it's worth checking the switch but I expect the BSI relay OR the wiring harness to the door itself, will be worth investigating.
Threads: 123
Thanks Given: 250
34
Mine did the same, there's a thread on here from a few years back about the issue. It might well be the 'green relay' controller that sits near by the accelerator pedal.
Mine would sometimes allow the window to go down but not up again unless I turned the ignition off & on again.
Threads: 75
Thanks Given: 223
164
Ah thanks CC, seems again I forget its an M59.
Threads: 123
Thanks Given: 250
34
No problem, just remembered that mine also did it when cold / damp but not in summer!
Threads: 8
Thanks Given: 8
I found the thread mentioned but it does not seem to provide a definitive answer.
The frustrating thing is that it currently works more than it doesn't and of course when I have time to spare to investigate it works !
Threads: 75
Thanks Given: 223
164
Try a standard BSI reset?
