Threads: 54
Thanks Received: 81 in 75 posts
Thanks Given: 147
7
Hi fellow K9-ers.
I've got manual AC on my K9. I find that the vent temperature varies significantly with vehicle speed, I have to turn temp up on sections of open road when cruising along and turn the temp down when driving at lower speeds.
This isn't a major problem to me but I wondered if others had noticed similar, and/or whether people have found a combination of settings that alleviates the problem at all.
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
I have an automatic A/C in my K9 but unlike any other car I have or had it performs differently, heavily dependent on whether the recirc is on or not. Should not be.
ex: 2003 1.4i cargo
Threads: 19
Thanks Received: 31 in 30 posts
Thanks Given: 12
16
11-10-2022, 02:02 PM
(This post was last modified: 11-10-2022, 02:12 PM by Mark604.)
I have manual A/C on my K9. What I can say is the faster I go, the colder it seems - maybe it is just the amount of cold air coming out the vents.
I spend a lot of time on European motorways and in the summer when 40 degrees is not so unusual now and once I've built up speed for a while, the temperature I set it at stays at 'low' or 14 degrees and I don't adjust it. The fan stays on the lowest setting and the inside stays plenty cold enough.
If I then go into a town, after a short while I have to turn the fan up to feel the same amount of comfortable cold. Recirculation is off.
In winter, and I easily go to places where it is minus ten or so, the A/C stays off and the faster I go, the hotter it seems - again probably because of the amount of air being pushed through the vents. Slow down and I have to up the temperature and/or up the fan speed.
In intermediate months I can't get it quite right, if the temperature I set is say, 22 degrees for the cabin, with the A/C off, warm/hot air is pumped out - if the A/C is on, cold air comes out the vents. It may well depend on what the outside temperature is, when not too hot or too cold, in comparison to what I want.
Now a 2019 K9 1.2 petrol.
Threads: 54
Thanks Given: 147
7
Thanks for replies, I'll test to see whether temp is less sensitive to road speed with re-circ on
Matt
previous
Threads: 4
Thanks Received: 4 in 4 posts
Thanks Given: 9
I too have noticed this.
I always used to drive with A/c on when the company I worked for paid for fuel but now I run my own van I tried without a/c and think the temperature is more stable as well as saving fuel. Any thoughts?
Only use a/c for demist in morning or if too hot. Noted the a/c switches on automatically if I turn temperature right down.
2019 Citroen Berlingo 1000 Enterprise M 1.6 BHDi SS
2014 Volvo XC90 2.4
2013 VW Polo 1.6 HDi
The following 1 user says Thank You to prj63 for this post:1 user says Thank You to prj63 for this post
• Matt Haigh
Threads: 11
Thanks Received: 15 in 9 posts
Thanks Given: 1
I have had many vans with the same issues, I’m in the van 10-12 hrs a day and it drives me nuts having to keep adjusting the settings.
I had a new Driver edition 100 which I spec,d with a auto heater, I’m hoping to report happy news soon….
K9 XL Driver 130EAT8 2024 94k Dec25
Threads: 20
Thanks Given: 7
15
I leave mine set on windscreen and footwell and have the dash vents closed as I have always found dash vents annoying!
Set to around 19 degrees and that seems to work nicely for me
The following 1 user says Thank You to Tree for this post:1 user says Thank You to Tree for this post
• Matt Haigh
