10-02-2012, 07:28 PM
hi all ive had the berlingo a week now. first problem was the engine cover as all the holding post were broke off and the cover was just sitting there.i see that there is a nice modded set on the bay for 15 squid they look a lot stronger too,i will be ordering a set soon. replaced the wipers to day with the flat areo ones that seem a lot better. new clutch cable arrived this morning after reading up on the site you recommend this to help with the heavy clutch peddle i hope it works. also the side sliding door handle is not working so i have a new pin comming from poland.ill get there in the end!! a couple of questions please is the cable easy enough to fit and also the repair to the door handle as i would have thought that a few of you lads had done these jobs....thanks baz.
