  • 21 Vote(s) - 3 Average
[Transmission] juddering
my van seems to have developed a juddering over time but only when im driving with the smallest amount of throttle, i think it may be the mass fly wheel. has anyone else had this problem. its very annoying when i want to drive economical
I doubt it will be the DMF mate Smile
i had the same problem on a vauxhall combo garage replaced mass fly wheel and it solved it.
M59 doesn't have a DMF
good cause they are expensive
so maybe the cluch or gearbox
Wink
(10-02-2012, 10:10 PM)berlingo power Wrote:  my van seems to have developed a juddering over time but only when im driving with the smallest amount of throttle, i think it may be the mass fly wheel. has anyone else had this problem. its very annoying when i want to drive economical
HI, I have a 04 HDI which does the juddering bit, only seems to do it in a high gear at a low speed when i hit the throttle lightly, I think its part of the citreon package. its worse when its cold, could be the choke that as stayed on to long. could be a duff set of engine mountings or worn driveshafts, mine as done 55K.:brickwall:
yeah engine mounts ill check them next that sounds posible, it didnt do it when i first bought it.
Is it a 2.0 hdi?
Driveshafts gone after 55k then don't think i'll ever be buying a citroen again!
2.0 HDI ???? Crankshaft pulley/Damper???
Leaking windscreen or aerial
Last Post: Guanajuato
Today 09:05 PM
Apple Carplay
02-04-2026 01:26 PM
