Sliding Door rail covers?
Hi guys, new to the forum and Berlingos, having just bought a 2014 reg. I’ve noticed the paint has flaked off on both the sliding door rails and was wondering if anyone had purchased any of the side door rail trims found on eBay? I was tempted to paint them again but I presume it wouldn’t be long before the same thing happened again? Was hoping the chrome trims would be an easier and longer lasting fix?
https://www.ebay.co.uk/itm/174754558155?...media=COPY
I presumed this was something that happens to most Berlingos, so wondered what people tend to do, or do most just leave it?
Thank you.
Rodd
I had the same happen to mine, It had been re-painted but poorly and had flakes coming off it, It does seem around the 14 plate year as mine is you start to get this happening don't know why,
I removed the middle runner and sand blasted it, I then base coated in primer and sprayed it gloss black which so far has not started flaking.
Drive A Berlingo/Partner 1.6hdi 14-Plate Undecided
[-] The following 1 user says Thank You to Sikez2012 for this post:
  • Jeffree
(22-10-2022, 06:58 PM)Sikez2012 Wrote:  I had the same happen to mine, It had been re-painted but poorly and had flakes coming off it, It does seem around the 14 plate year as mine is you start to get this happening don't know why,
Thank you. It is strange, I’ve seen some that look completely fine, even on older cars. Are the rails easy to remove for painting? I’m not great at mechanical work so unless it’s easy I could just ask a body shop to do it if it’s not to expensive. Noticed on eBay there are second hand rails for £25 each, which look good condition, just seems crazy replacing a part just because aesthetics though. Thank you for the reply.
Rodd
I have a 67 plate and one side is flaking and the other isn't.
Mines a 17 and it's flaking off. I'm planning to remove the centre rail without disturbing the door or the top and bottom rails, then strip it back to bare metal and recoat the alloy it's made from.
Removal from memory:
Remove the torx from the end/stop cap and then remove the torx bolts that hold the rail on to the body..3 more i think
Then the middle section will come of …It will come of towards you and then you move it towards the front sliding the centre bearing out the end the door will then be held on by the top/bottom rollers
Refitting is pretty much reversal of the above sliding the middle bearing onto the runner before re-fitting
There an alignment lip that fits into a hole virtually on the bend you will see when removing it.
That's its basically fit the bolts holding the runner on and then fit the end cap and test it opens/closes ok.
[-] The following 2 users say Thank You to Sikez2012 for this post:
  • Jeffree, Sol
Yesterday 04:12 PM
Yesterday 12:46 PM
Yesterday 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
