Threads: 11
Thanks Received: 7 in 6 posts
24-10-2022, 11:46 AM
(This post was last modified: 24-10-2022, 11:58 AM by 5EAN.)
I've got a 2020 K9 van if it was to brake down or not start etc and needed towing is there a way of taking the electronic hand brake off to tow or bump start etc i have read that other models of cars/vans have a over ridding system on the brake pedal i'm just curious and nothing to do today.
Threads: 10
Thanks Received: 37 in 36 posts
Thanks Given: 21
24-10-2022, 01:09 PM
(This post was last modified: 24-10-2022, 01:16 PM by boop.
Edit Reason: clarification
There's a procedure described in the manual. From memory:
1. Ignition on
2. Shifter to neutral (holding the brake)
3. Hold brake button down for a few seconds.
ex: 2003 1.4i cargo
Threads: 63
Thanks Received: 902 in 802 posts
Thanks Given: 145
108
You still have Neutral...
Threads: 10
Thanks Given: 21
There's no difference. Just checked the manual, there is the procedure laid out but it's more complex than the one I used:
1. Engine on
2. Parking brake on
3. Release brake pedal
4. Push parking brake release and hold 10-15 sec
5. Release the button
6. Push and hold brake pedal
7. In 2 seconds pull parking brake towards "on"
8. Automatic brake blocking mode lits up in the instrument panel
8. Release button and brake pedal.
Repeat to revert.
ex: 2003 1.4i cargo
