Radio
What does the radio puller key look like for my 2013 Berlingo MPV - can someone tell me please?
Ta.
Looks like 4 pop rivets in the holes, gentle pressure and pull out
(25-10-2022, 09:33 PM)Chris666 Wrote:  Looks like 4 pop rivets in the holes, gentle pressure and pull out
Yes here is a pic.
Attached Files Thumbnail(s)
Here are the ones I have:
https://www.halfords.com/motoring/tools/...sCEALw_wcB
Remember if you remove the stereo and swap it, you lose a lot of functionality on the info screen and the buttons on the steering wheel, cannot set the clock or change functions etc. It has an ECU inside it that is the controller of the main orange display screen (for fuel, MPG, trip etc)
(26-10-2022, 12:14 PM)Zion Wrote:  Here are the ones I have:
You can gain it all back with a connects2 module, worth factoring in the cost when changing head unit
You do indeed, I changed my head unit and haven't fitted a Connects2 yet as I grudge spending £65 to get the button control back.
  • Chris666
The easy way is to pull out the tray under the radio. push the radio out from behind. easy to get out that way. should you mount aftermarket radio. i would recmend Teyes cc2 or cc3. i have had this 9" radio for 2 years, and i love this radio. i have also mounted tpms sensors so i get a low tyre pressure warning.
backup camera, front trafic camera. and you have all the things you need and lots more (the mid display also works. ) And yes if you should go for pionner,kenwood,jvc etc. you should get the connects2 kit. ctspg0072 and your mid screen will work as normal.
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
