1.9d Lucas berlingo died while driving
It was doing 90kmh and all of a sudden it lost power and stopped...no strange noises nothing. I opened the hood and noticed water pipe was blown and leaked all of the water, the temp on dash was spot on normal.
I tried to crank it and it just cranks fast with no strange sound. I opened the valve cover and the valves look OK.
2007 1.9d van
Maybe water got on electronics. Does the dash light up? Check fault codes.
[-] The following 1 user says Thank You to SinsBird for this post:
  • VaseMK
Dash lights are fine and gauges work as should. Don't have a obd scanner to check for errors...
Is the check engine light on? If so you'll have to find someone with a scan tool. Hopefully the engine hasn't lost compression IF it overheated.
(30-10-2022, 03:26 PM)SinsBird Wrote:  Is the check engine light on? If so you'll have to find someone with a scan tool. Hopefully the engine hasn't lost compression IF it overheated.
The check light is on but I have removed airflow sensor, it wasn't on before that.
Guess ima need to open the head...
BTW how does it crank if it won't read the code and does it give a warning light?
Sorry, I don't understand what you're asking in the last sentence.
(30-10-2022, 03:36 PM)SinsBird Wrote:  Sorry, I don't understand what you're asking in the last sentence.
Example I'm using other key that can turn but has other code on it. I'm asking If I have issues with the immobilizer..
Possibly.
(30-10-2022, 03:57 PM)SinsBird Wrote:  Possibly.
Yeah but does it crank as about to start or it cranks as it has no compression  Sad
The fuel gets cut off, so it should crank rather fast.
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
