Recommended diagnostic tools for M49 Berlingo
Hi all,
I have recently purchased a 2001 Berlingo for use as a 'work van'. I have seen 'Lexia' mentioned a few times on these forums, as the dealer level software for this vehicle.
I am an automotive locksmith and already have a bunch of equipment, and wondering if getting an interface for Lexia will provide any extra advantage for me with this old Berlingo.
I currently have:
- AUTEL MX808
- AUTEL IM508 + XP400 Pro + G-Box 2
- xHorse Mini OBD Tool + Keytool Mini + Mini Prog
- A generic OBD2 scanner
- J2534 VCI
Is there any point getting an interface for Lexia, or do you think my current tools will cover most things I will need?
The M49 will not be standard OBD yet and probably only has basic diags of the engine over K-Line, I'd think your 808 would do all you need but it never hurts to have Diagbox (Lexia is the older version of Diagbox and now refers to the interface - properly known as an Actia interface)
You would be best to get a Diagbox full-chip kit if you really want the OEM stuff, and it only does Citroen and Pug stuff, but is good, if you can be arsed installing it (it's a pig) and it needs Win 7/32.
Why not try the 808 on it first, see if it connects, do a live data run and see if you get stuff like fuel pressure, airflow etc and if so, I'd stick with what you have.
  • bertylingodave
(01-11-2022, 09:14 PM)Zion Wrote:  The M49 will not be standard OBD yet and probably only has basic diags of the engine over K-Line, I'd think your 808 would do all you need but it never hurts to have Diagbox (Lexia is the older version of Diagbox and now refers to the interface - properly known as an Actia interface)
I'll check the MX808 in the morning and see how it goes..
I might get a Diagbox anyway, as I already have a laptop setup with a bunch of virtual machines for specific tools for my other cars (BMW and VW).
Thanks for the info
I'd love an mx808. It's quite a serious weapon. Unless you're going to do configuration changes then Diagbox won't be much more help but it is good for that stuff.
It is a PIG to install btw.
(02-11-2022, 05:56 PM)Zion Wrote:  I'd love an mx808. It's quite a serious weapon. Unless you're going to do configuration changes then Diagbox won't be much more help but it is good for that stuff.
Can't be much worse than installing the GlobalTIS/Tech2Win stuff, or older BMW software..
The MX808 is a great tool. Used it yesterday to diagnose an issue with a 2012 Peugeot 308.
Anyway, I'll head out to the M49 shortly and see what info I can get from it.
2011 B9 DPF warning light
Today 12:07 PM
Today 10:53 AM
Frequent DPF REGEN's
Yesterday 08:43 PM
Power Steering gone - reservoir full, hoses and ...
Last Post: Collapsedsuspension
Yesterday 02:29 PM
Power flex anti roll bar bushes
Last Post: NANO_Vigo
Yesterday 10:54 AM
Power flex lower wishbone bushes
Last Post: AD246
Yesterday 08:54 AM
How to change your username
Last Post: Mike
16-01-2025 11:04 PM
Spot the Berlingo(s)
16-01-2025 12:20 AM
knocking from rear
15-01-2025 04:59 PM
Last Post: Andhall
15-01-2025 04:59 PM
