Threads: 59
Thanks Received: 11 in 10 posts
Thanks Given: 49
I can see there is a vacant terminal to attach a positive wire to but I cannot find a way to pass the wire through to the cab. Has anyone done this?
Threads: 75
Thanks Given: 223
164
02-11-2022, 05:53 PM
(This post was last modified: 02-11-2022, 05:54 PM by Sol.)
Use the grommet through which the bonnet release cable passes. You will have to puncture that grommet. There are no ready made routes.
• John Bilko
Threads: 39
Thanks Given: 1
4
When our Romahome was built they broght the cables from the engine into the cab using a cable gland fitted to the plate that covers up the hole for the LHD steering column. I have just fitted anothe next to it.
Peter
Threads: 39
Thanks Given: 1
4
The plate is riveted in place and they just drilled a hole in it. They cut a hole in the carpet but I pulled it back to do the second one.
Peter
Threads: 75
Thanks Given: 223
164
03-11-2022, 06:57 AM
(This post was last modified: 03-11-2022, 06:59 AM by Sol.)
John Bilko - I didn't realise you were prepared to drill a hole...instead looking for an existing route. There are of course many places if you are just going to drill a hole and put a gland in.
Threads: 75
Thanks Given: 223
164
(03-11-2022, 01:08 PM)John Bilko Wrote: (03-11-2022, 06:57 AM)Zion Wrote: John Bilko - I didn't realise you were prepared to drill a hole...instead looking for an existing route. There are of course many places if you are just going to drill a hole and put a gland in.
I do not want to drill I must confess. I tried going with the bonnet cable and got nowhere. Hopeless I am. lol
Not at all mate, it isn't always easy to see these things - that engine bay is pretty congested. Imagine where the steering shaft would go through if you were sitting in the passenger seat - maybe that would point you to the right area. On the bonnet cable thing, it leads from the latch on the passenger door frame, and up the wall behind the glovebox then out to the wing, and round to the bonnet latch - maybe you can follow that back. You would have to puncture the rubber grommet to get a wire through,
