Automatic parking brake
Does anyone know of a way of not having the automatic parking brake being applied when switching the engine off?
I know that’s a strange question but when I park our MK3 Belingo flare 2019 in the garage for any length of time I don’t want the parking brake on as the brake starts to stick to the drum.
All my other cars I just simply left the handbrake off but my Belingo insists on having it applied as soon as the engine is switched off.
Thanks for any suggestions ?
Oh I found this now … only problem is I can’t access any menus as the buttons surrounding the radio are unresponsive. Dealer said it was covered by the three year Citroen warranty and ordered the part but no idea when the replacement will arrive , if ever ?! Are these buttons the only way of accessing the settings ?
Attached Files Thumbnail(s)
There should be electric parking brake section in the handbook.
(02-11-2022, 06:55 PM)Julesanian Wrote:  Does anyone know of a way of not having the automatic parking brake being applied when switching the engine off?
Free-wheeling
In certain situations, you must allow the vehicle
to free-wheel (while being towed, on a rolling
road, in an automatic car wash, or being
transported by rail or sea freight, etc.). 7
The procedure varies according to the type of
gearbox and parking brake.
With a manual gearbox and
Release procedure
► With the engine running and while depressing
the brake pedal, move the gear selector to the
neutral position.
► While depressing the brake pedal, switch off
the ignition.
► Release the brake pedal, then switch on the
ignition again.
► While depressing the brake pedal, press the
control lever to release the parking brake.
► Release the brake pedal, then switch off the
ignition.
Reverting to normal operation
► While depressing the brake pedal, start the
engine.
I am sure that on my K9, if I press down footbrake, then stop/start button, I can release the handbrake manually by moving the switch while keeping the brake pressed.
Geoff
MOT Emissions repeated fail
Last Post: Marsaday
Today 10:41 AM
Rear door filling with water
Last Post: Marsaday
22-01-2026 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
