Cloudy headlight
One of my headlights is cloudy/discoloured, if I clean it with cutting paste and T-cut it will stay clear for a while but then goes cloudy again. I know polishing kits are available, but do they give permanent results or is there something else that I could use that I may have 'on the shelf' before I spend money on a kit?
My van: 2008 Berlingo 1.6 HDi Enterprise - a bit ratty!
It needs lacquering with UV resistant lacquer after you get it clear.
I had the same issue with my wife's Peugeot 307. I polished them to perfectly clear, but this only lasted ~1 year.
The original headlights have been coated with UV-resistant clear when they were manufactured, but with time the sun beats this to submission and you are left with just plastic that degrades pretty quickly with ths sun shining on them.
You have three options.
1. Buy new ones, but they are always expensive and takes a lot of time to replace them.
2. Polish them (wet sanding from say from 600 to 5000 grit) and then apply a protective plastic film. See from this person here: https://www.youtube.com/watch?v=UG54xt56uZo I tried that, but the 307's headlights are somewhat domed and I could never do it without having bubbles underneath and the domed part cannot be done with the plastic film as it does not stretch too well. You may try it with the Berlingo, headlights are pretty flat (not too sure about the 2008 version), so should be doable. That is the easiest way of them all.
3. Wet sand them (600, 1000-1500 grit only). Then spray it with clear coat and wet sand 2,000-4,000 and cutting/polish compound. I did that and it is nearly perfect now. I made a stupid mistake the first time. I wet sanded them 600, 1000, 2000, 3000, 5000 and 7000 grit. They were perfect, better than new. Then sprayed the clear coat, but the clear dries into kind of a spidernet shape or cracks a lot or one can explain it as hairline cracks. I had polished it too good and the clear does not have anything to get hold of, no micro cuts to get inside. Similar to spraying clear coat on a mirror. Sand again and I left it at 1000-1500 and that was pretty good. Of course cutting compound and polishing afterwards. The clear was from a can and I think from paints4u from ebay. Pretty good clear, not 2k, but just the normal 1k. The sanding paper from amazon, some generic A4 sheets, they are pretty cheap. The clear coat lacquer lasts, but you have to be careful not to sand it out. It depends on the thickness of the clear you have put down. I did a few passes of clear coat lacquer, leaving ~15-20min between each coat to harden a fair bit, but that depends on the temperature, the hotter the temp the shorter the interval of clear coat.
If you are interested I can post where I bought all my things.
[-] The following 1 user says Thank You to saskak for this post:
  • RattyCortina
Thanks for the replies.
TBH it sounds like a right faff to get good/lasting results, as there was no mention of a problem at the MOT it looks like something to think about in the better weather.
(Like the sloppy clutch pedal LOL)
We have a friend with an ancient Honda and "discoloured headlamps came up as an advisory on the MOT a couple of years ago, now as part of his MOT prep he cleans the headlamps with toothpaste
Peter
(06-11-2022, 08:40 AM)RattyCortina Wrote:  Thanks for the replies.
It is not too bad, but a lot of wet sanding to get good results. If I were you I would wait for a warmer weather, ~17-20C is perfect. If there is too much humidity in the air it will ruin the clear lacquer, unless you have a heated garage.
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
