Threads: 11
Thanks Received: 5 in 5 posts
Thanks Given: 83
[attachment=7788]Anyone know?
Thanks Received: 15 in 15 posts
Thanks Given: 1
07-11-2022, 09:25 PM
(This post was last modified: 07-11-2022, 09:30 PM by SinsBird.)
On our Renault it's 4th (when counting from left to right while standing in front of the engine) if I remember correctly.
Threads: 75
Thanks Given: 223
164
07-11-2022, 10:17 PM
(This post was last modified: 07-11-2022, 10:27 PM by Sol.)
Citroen cylinders are numbered right to left. No1 is at the gearbox end (RHS as you look at the engine)
terminal 4, to each plug output in turn is pins 1, 2, 6 & 7.
The following 2 users say Thank You to Sol for this post:2 users say Thank You to Sol for this post
• RJBingham, saskak
Threads: 75
Thanks Given: 223
164
08-11-2022, 09:54 PM
(This post was last modified: 08-11-2022, 09:56 PM by Sol.)
(07-11-2022, 09:25 PM)SinsBird Wrote: On our Renault it's 4th (when counting from left to right while standing in front of the engine) if I remember correctly.
Renault?? Do you actually have a Berlingo? You give a lot of advice but quote Renault and the opposite numbering a Citroen engine uses. You do realise this is a Citroen Berlingo forum?
Thanks Given: 1
We have 2 M59s at the moment. That's exactly why I say in the beginning that it's a Renault, because the information may be irrelevant.
Threads: 75
Thanks Given: 223
164
09-11-2022, 10:38 AM
(This post was last modified: 09-11-2022, 10:39 AM by Sol.)
Ok. The plug pictured is from an HDi glow control relay, which the M59 comes with (when it's not a 1.9D) - I still don't get the Renault reference.
Renault and Citroen could not be more different too. No connection between them.
Threads: 8
Thanks Received: 507 in 455 posts
Thanks Given: 305
37
Why not use the multimeter to figure out what contact on the multiplug is for what glow plug, just do a continuity test between the wire that connects to the glow plug and the contact in the multi plug.
• RJBingham
