Threads: 19
Thanks Received: 7 in 6 posts
Thanks Given: 7
Hi. Im looking to upgrade my headlights to led's. Ive seen loads on the internet but not sure which to get. Is anyone using any snd if so which ones.
Sent from my NTN-LX1 using Tapatalk
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
Do other drivers on the road a favour and leave the standard headlights alone.
Which ever LED's you fit will blind oncoming drivers, factory fitted LED lights on all makes of vehicle do this.
The following 2 users say Thank You to jj9 for this post:2 users say Thank You to jj9 for this post
• Pedronicus, saskak
Threads: 54
Thanks Given: 147
7
I'm not sure if there are any which are legal to fit on a UK reg vehicle. Its likely that the eBay/Aliexpress bulbs are illegal, check the tech specs carefully.
Matt
previous
2016 1.6 HDi 100 XTR Grey Met
2010 1.6 HDi 105 XTR Gold Met
Thanks Received: 5 in 5 posts
Thanks Given: 8
11-11-2022, 09:49 AM
(This post was last modified: 11-11-2022, 09:51 AM by Chris666.)
No legal route to doing this, the projector lamps in bulb units are completely different in order to spread softer light IIRC.
I just changed my bulbs to +150%, possibly +200% ones, not the same thing but a huge difference over standard bulbs
Threads: 19
Thanks Given: 7
Which bulbs did you get? Definitely need something better than stock. The Mrs BMWs LEDs are amazing in comparison
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
(11-11-2022, 11:33 PM)Stevie C Wrote: I bought some these for my b9 not blinding but ok and mounting plate removes to fit first then lamp mounts in that like a bc lamp making fitting easy only about 10 pair.
https://www.ebay.co.uk/itm/394197264939
They're not road legal.
Cooper just fit nightbreaker 200% bulbs in H4 format.
• Pedronicus
Threads: 6
Thanks Given: 22
My wife has been having to use the Berlingo at night and is finding the headlights poor, particularly in the country roads.
Are the Osram Night Breakers still the preferred upgrade? And, if so, is the wiring up to taking the extra current being drawn?
If so, these seem a good price unless anyone knows a better source?
Osram Night Breakers - Amazon advert
Many thanks
Brian
___________________________________________________________________________
Multispace 2016 II B9 04/2008 1.6 BlueHDi 100 - engine 1560cc 73KW 99HP BHY (DV6FD)
Threads: 75
Thanks Given: 223
164
02-02-2023, 12:20 PM
(This post was last modified: 02-02-2023, 12:22 PM by Sol.)
Yes, and yes. The wattage is the same (has to be or they would not be legal) but the light output is higher.
Not bad price, I paid £19.99 for the +200% ones. Also, get an MOT garage (or Kiwk-s**t) to check and adjust the beam alignment, could be off. Costs £15.
• BrianS
