Windscreen scuttle nut? ident
I've removed the 2 pieces of plastic scuttle between the windscreen and bonnet on my M49, in order to remove gunge that had accumulated beneath. There was no gunge in the nearside drain area and a few handfuls in the offside, now all cleared, though it didn't look enough to cause blockage.
Anyway, when it comes to putting the scuttle pieces back, I've found a sort of flanged nut beside where the 2 scuttle pieces overlap and are screwed in with a torx screw - see pic below (unidentified nut to the left of the connection point, torx screw to the right).
As I removed the nearside bit of scuttle first, which was under the offside bit, I'm not sure where this nut (if that's what it is) fits in, as I didn't see it during dismantling. Any ideas? The nearside bit of scuttle also has a split in the connection tab (visible on the pic) - I might have caused this when taking the nearside scuttle out first. Does this matter?
The other half of the scuttle fits over it and the screw holds both sides.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Thanks. Does that mean it's supposed to go between the two bits of scuttle?  I fiddled around a bit and it seemed to fit best when I placed it under both bits of scuttle, with its raised central bit pointing upwards through the fixing holes in both of them.
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
