My son recently bought a 2006 Berlingo van 1.4 petrol, with what appears to be a factory fit LPG system. Unfortunately after a few weeks the head gasket is showing signs of failure, and he's been advised it isn't worth repairing.
I'm quite interested in rescuing it for myself - it's in good condition, 60,000 miles and drives very well. I quite fancy making a mini camper out of it!
The engine looks fairly straightforward to work on, but does the LPG setup complicate gasket replacement, and are there any pitfalls to be aware of?
Many thanks.
Threads: 118
Thanks Received: 606 in 564 posts
Thanks Given: 234
33
Welcome.
I'm no expert on LPG conversions so I may be wrong but I doubt there's any difference to the gaskets used. I suppose the only thing to be aware of is that you'll need to get it checked for gas leaks by a specialist for peace of mind. If you search the form for LPG, there are a few others on here with them, so a post on those threads may help more.
Thanks Received: 11 in 11 posts
Thanks Given: 1
If oil and coolant are not mixing you could try a head gasket sealer. After repair be sure to take the car to LPG specialist to check if the air/fuel mix is correct.
Threads: 63
Thanks Received: 902 in 802 posts
Thanks Given: 145
108
Thats what I would do, remove the LPG and put it back to standard. Then the gasket is a straightforward job, and they are kind of known for blowing head gaskets I believe. (the 1.4 engine that is) although I've never had one, all mine were diesels.
Threads: 52
Thanks Received: 669 in 568 posts
Thanks Given: 145
43
" Just curious, how so on the first question? "
The 1.4 petrol engine is nothing special - bog standard simple affair.
With respect to the LPG and head gasket replacement it is simply a case of a few extra bits to remove and replace.
No need to worry about the gas as there will be shut off valves to take care of it, naturally you'll not have naked flames as with petrol.
LPG - refitting gas piping only needs leak checking so use a strong soapy liquid on any disturbed joint and look for bubbles.
Removing the LPG permanently ?
Personally I'd leave it in place and just use petrol, this way you avoid any issues with " modified vehicles " and your insurance policy.
• cancunia
Threads: 39
Thanks Received: 362 in 321 posts
Thanks Given: 122
23
From Geoffs reply , does it mean you can use petrol if there is no LPG supply around ?
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 52
Thanks Given: 145
43
^^ Fuel choice is optional
