Threads: 6
Hi, my Berlingo has a P0711 code (transmission oil temperature sensor fault) but I believe the '04 1.9d doesn't have that sensor fitted can anyone give me any pointers as to where I can start looking?
Engine check light only comes in when coasting then disappears when I begin accelerating again.
Threads: 39
Thanks Received: 362 in 321 posts
Thanks Given: 122
23
Sounds like a bad connection somewhere to something which makes or breaks depending if the engine moves forward or backwards on its mountings when you accelerate or slow down.
I would delete it and retry . If you dont have automatic transmission then its a spurious reading.
Try a BSI reset
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 6
Okay thanks what's a BSI reset?
