Threads: 75
Thanks Received: 1,309 in 1,140 posts
Thanks Given: 223
164
22-11-2022, 09:17 PM
(This post was last modified: 22-11-2022, 09:17 PM by Sol.)
(21-11-2022, 09:26 AM)deejay_xb Wrote: Clutch is not the problem, you need to replace engine/gearbox mounts, use search because this problem was already discussed
Spot on. The lower rear engine mount (torque link) is the problem, not the clutch. The other two engine mounts may be soggy too.
Threads: 8
Thanks Received: 4 in 3 posts
Thanks for the advice its back in tomorrow. See what's found.
Drive A Berlingo/Partner 1.6hdi 14-Plate
Threads: 8
Just to conclude, The vans now back and drives spot on, It required a flywheel, Replacement clutch fitted and flywheel due to high spots on the flywheel clearly visible on the pressure plate.
Another job ticked off.
Threads: 75
Thanks Given: 223
164
That wouldn't be cheap. Glad it's working.
