Threads: 2
Thanks Given: 3
Hi all,
Have had my Berlingo for 2 weeks.
2018 Berlingo Enterprise panel van 1.6HDI (don’t know the model code).
Really enjoying the practicality of a van.
Only problem so far encountered is the cruise control.
Worked perfectly for 2 weeks when needed but yesterday wouldn’t engage.
Haven’t tried since so may be trawling through your posts if it doesn’t work again.
Threads: 123
Thanks Given: 250
34
Welcome.
If you still get problems with the CC, there's a fair amount of experience on here. It will be useful to know the model variant that you have, chances are that it's a K9, but could also be a late B9. There are plenty of pictures online to guide, but if in doubt just post a picture in the forum and someone will help.
Threads: 2
Thanks Received: 56 in 52 posts
Thanks Given: 38
8
Check and clean the trailer plug socket if equipped. Any shorts/current leaks in brake light circuit there would cause CC to disengage.
ex: 2003 1.4i cargo
The following 1 user says Thank You to boop for this post:1 user says Thank You to boop for this post
• Emperor888
Threads: 2
Thanks Given: 38
8
Is it the latest model with a camera based ACC or the previous body with no adaptive CC?
ex: 2003 1.4i cargo
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
Doesn't the 1.6HDi give it away? I don't know much about the K9 but I thought they were 1.5 and 1.2 engines and not using the 1.6HDi any more.
