Door check strap
Hi all
'64 plate XTR
Im getting a horrible loud CRACK noise when opening the drivers door.
Im pretty sure that its the check strap at fault, so I have blitzed it with lithium grease but little difference.
Do you have to remove the door card to swap one ??
Im not as handy as I used to be so will have to get someone else to do it if that is the case.....
Many thanks all
Richard
You do need the door card off, as the check strap can only be removed by pulling it into the door cavity. It fits from the inside out. It requires the speakers and lining membrane to be removed as well. It is a bit awkward to be honest.
[-] The following 2 users say Thank You to Sol for this post:
  • rickandbev16, Ringo2024
Some time ago I have prepared a little step by step guide...
[-] The following 2 users say Thank You to Buki for this post:
Please note...You can easily break the door card clips when dismantling the door card. It would be a good idea to buy some new clips before you start.
[-] The following 3 users say Thank You to Buki for this post:
  • Berlinguist, rickandbev16, Ringo2024
Buki, thanks for this. I'm going to sticky this thread.
Thanks Zion. At the photos in the last post, you can see the wear on the center of the white plastic roller, this is what causes the mentioned noise. Therefore, lubricating this part does not help in any way, only replacing it with a new one.
Users browsing this thread: 2 Guest(s)
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
