Threads: 10
Thanks Received: 3 in 3 posts
Thanks Given: 2
Afternoon all. Just been to our local factors to get a set of balljoints for our 2006 Desire and was told only whole arms with balljoints are available for these cars at £80 pep side. Is that the case? Thanks in advance
My vehicle:
2006 Citroen Berlingo Multispace Desire 1.6HDI
Threads: 123
Thanks Given: 250
34
IIRC there are 2 versions, one with a bolt on ball joint, and the other all in one. Not sure if it's possible to change from one to the other.
Threads: 67
Thanks Received: 716 in 613 posts
Thanks Given: 236
50
25-11-2022, 04:10 PM
(This post was last modified: 25-11-2022, 04:16 PM by geoff.)
These days I always work on the basis that if a bottom joint is " gone " then the wishbone bushes will be past their best before date as well, I always swap out a complete wishbone for convenience.
That said, I have in the past changed just the bottom joint in situ on other cars, including my last Berlingo 1.9d
My 1.6 Hdi has the cast arms so different on that model
Serieal Berlingo owner
Threads: 39
Thanks Given: 1
4
Shop around you will find them cheper, plus if the ball joints are rivetted in they can be remob=ved and replaced bt bolted ones
Peter
Threads: 8
Thanks Received: 499 in 448 posts
Thanks Given: 305
33
(25-11-2022, 03:59 PM)cancunia Wrote: IIRC there are 2 versions, one with a bolt on ball joint, and the other all in one. Not sure if it's possible to change from one to the other.
I believe they are interchangeable, but I haven't tried personally.
Some info in the threads below ....
https://www.berlingoforum.com/thread-16242-page-2.html
https://www.berlingoforum.com/thread-15123.html
Threads: 29
Thanks Given: 67
20
(25-11-2022, 03:30 PM)Chips\n'gravy Wrote: Afternoon all. Just been to our local factors to get a set of balljoints for our 2006 Desire and was told only whole arms with balljoints are available for these cars at £80 pep side. Is that the case? Thanks in advance
Ours has cast wishbones and i changed one this year for MOT at a cost of £43. It was only replaced a couple of years before that and had not done many miles but the ball joint was well and truly shot.
Threads: 10
Thanks Given: 2
Thank you all.
All makes sense. Inspected the wishbones last night. Yes, they are a single unit with the balljoint and yes, they are pretty much knackered. Rubber cracked and separating from metal etc, so time for new ones, ouch..
My vehicle:
Threads: 13
Thanks Received: 32 in 24 posts
Thanks Given: 8
They are dead easy to DIY change if you are used to working on cars. Worth doing the ARB bushes at the same time whilst you're in the area.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4 208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Threads: 10
Thanks Given: 2
Thanks, will do!
My vehicle:
Threads: 26
Thanks Received: 31 in 28 posts
Thanks Given: 8
9
Do I start my Chinese ball joint rant?
220,00 miles, (Resurrected at 186,000)
