Threads: 5
Thanks Received: 1 in 1 posts
Thanks Given: 11
Short drive home, the main fan , kept running, would of if I didn't disconnect the battery, fine after? No warning signs or issues
Sent from my 2201116SG using Tapatalk
Threads: 5
Thanks Given: 11
2013 1.6 hdi xtr
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
Likelihood is, it would have been doing a DPF regeneration and you stopped the engine while it was active.
It then has to run the fans for quite a while to cool the DPF down again - if it does this again, leave the fans to run or you could have issues with the DPF sitting at nearly 1000 degrees while parked up.
Have you not had this vehicle long? (Long enough to see it do this) as it's very common for people to stop a diesel while it was in the middle of a regen and the fans will run like buggery for quite some time..let them run. They will stop eventually. Also will smell a bit odd at the back of the vehicle while the fans are running.
If your journeys are normally longer on motorways then it probably does it's regens without you noticing.
The following 2 users say Thank You to Sol for this post:2 users say Thank You to Sol for this post
• Benny Blanco, LM42
Threads: 5
Thanks Given: 11
Thank you for the detailed reply, it's happened again, fan ran for over an hour , before I pulled the battery
Threads: 75
Thanks Given: 223
164
04-12-2022, 11:20 AM
(This post was last modified: 04-12-2022, 11:21 AM by Sol.)
Yeah sounds like something is actually wrong there. It would be worth getting a proper fault code scan done. If you can, then post the codes up here.
• LM42
Threads: 75
Thanks Given: 223
164
So the fans can run for two hours during an interrupted regen? Noted.
• LM42
Threads: 5
Thanks Given: 11
Very sure the battery would die before it turned off
