hello all..i have a 2001 1868cc Multispace Forte... every cold morning it will not start, and the glow plug light will not work... it starts ok now but the glow plug light won't come on. Then for the first 5 mins the indicators, heater/fan switch and wipers will not work. Then all of a sudden they come on. I will be taking it to a garage but before I do I'd like some advice as I feel a little vulnerable and don't want to be ripped off!! Thanks for any advice. Cheers. Sarah.
Threads: 21
Thanks Received: 36 in 34 posts
Thanks Given: 6
Glow plug relay mite be at fault maybe try a bsi reset for other fauts
The following 1 user says Thank You to muply for this post:1 user says Thank You to muply for this post
• Willie Fawcett
Threads: 0
Hi SarahJane,
I have the same electrical 'delay' problem on my 2001 petrol 1.8 Forte. I tried the BSI Reset to no avail. Did you get yours sorted at the garage & was it expensive?
Thanx
Threads: 50
Thanks Given: 743
Almost certainly a BSI or multiway connector problem. Assuming the BSI is undamaged then a Lexia reset should get it working.
Many private garages now have Lexia or the Pug equivalent and all you can do is to give it to them.
thanks for your advice..glad i dont have to do the bsi reset!!!..will take to a decent garage..anybody no of 1 in essex??..many thanks..Sarah
