[Steering & Suspension] Drop link query
Hopefully, this is a simple answer.  I have a drop link to replace the offside one.  It doesn't have a torx socket in the end of the threaded 'bolt section.  Is that a problem?
The other problem is that I've got to change it on my drive in the coming snow.  I must be bonkers....
(05-12-2022, 04:16 PM)sciteacher Wrote:  Hopefully, this is a simple answer.  I have a drop link to replace the offside one.  It doesn't have a torx socket in the end of the threaded 'bolt section.  Is that a problem?
They don't all have torx socket ends, some have a flat/squared end for an open ended spanner close to the rubber boot [so may not be obvious to see as it is the other side of the anti-roll bar fixing. Even if it hasn't got a flat end, it shouldn't be a problem, as it doesn't really matter if the thread on the old drop link gets damaged as you are replacing it. Spray it with some WD40 or suchlike and leave for a little while and try to undo the nut. If everything starts spinning grab the threaded end with a pair of locking pliers and then undo.
They are not too bad to do, normally about 30 minutes per side [including getting the wheel off/on] I normally change both at once and normally outside on the drive, the garage is too full of c**p  Smile
If you have access to axle stands as well as a jack, I've found they are much easier to replace with both side of the vehicle up in the air as if you just jack up the side you are replacing the anti-roll bar is under a lot of tension and makes it had to get the old one off and new one on.
[-] The following 1 user says Thank You to Multispacer for this post:
  • sciteacher
Clean up and lubricate the exposed thread before you try to get the nyloc nut off as well or it will turn the ball joint and stick.
Thanks chaps, the advice is much appreciated. Smile Smile
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
