Threads: 32
Thanks Received: 2 in 2 posts
Thanks Given: 24
How does the tyre pressure warning system work? I ask because when I fit my Peugeot alloys I don't want to be faced with warning lights or whatever on the dash.
Threads: 39
Thanks Received: 362 in 321 posts
Thanks Given: 122
23
07-12-2022, 07:30 AM
(This post was last modified: 07-12-2022, 07:30 AM by brodfather11.)
Some have sensors in the tyre valve and some calculate the radius of the wheel through the ABS .
If the tyre is down it acts like a smaller wheel and so more turns per mile than a fully inflated wheel/tyre.
The ABS can sense this. (I believe )
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Threads: 32
Thanks Given: 24
So today I watched the sequence of ignition start up and I saw nothing of a tyre pressure check icon. Does the TPMS warning light go through a check on starting up?
Threads: 10
Thanks Received: 37 in 36 posts
Thanks Given: 21
All our K9 Berlingos have ABS based pressure monitoring systems.
ex: 2003 1.4i cargo
Threads: 32
Thanks Given: 24
I am starting to think the only way I can establish if I have TPMS is to slightly deflate a tyre.
