Adding thanks
When I click add thank you on someone's post it always goes to an ad then a message saying thank you already added but often it doesn't appear beneath their post
My van: Berlingo HDi L1 90hp 850 Enterprise 2015
[-] The following 2 users say Thank You to Benny Blanco for this post:
  • brodfather11, Sol
I've added thanks to your post to see if it works for me.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
  • Benny Blanco
I sometimes find that a 'thanks' doesn't appear straightaway, though if I refresh the page, or go to another page and then come back, it has appeared.
I don't recall ads getting in the way of adding thanks, though they do sometimes prevent me from making a 'full edit' to one of my own posts - the ads tend to cover up the little drop-down menu that asks if I want to make a 'quick edit' or a 'full edit', and I can only click on the 'quick edit' option. Not that this has yet to prove an issue, it's just an observation.
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
