  • 9 Vote(s) - 3.44 Average
Bleeding brakes
hi guys need a bit of help.berlingo mk2 rear brakes.installed a new master cylinder without priming first.bled 3 corners with no problems.rear nearside coughs and splutters when bleeding with no real flow.I reckon ive spent 5hrs trying to bleed 1 nipple.I phoned a friend who asked me if the rear pressure regulating valve was seized.after looking at it i dont know but what difference would that make as it is still bleeding of sorts,and where is all the air coming from with no obvious leeks:brickwall:
(13-02-2012, 08:08 PM)clockwork Wrote:  hi guys need a bit of help.berlingo mk2 rear brakes.installed a new master cylinder without priming first.bled 3 corners with no problems.rear nearside coughs and splutters when bleeding with no real flow.I reckon ive spent 5hrs trying to bleed 1 nipple.I phoned a friend who asked me if the rear pressure regulating valve was seized.after looking at it i dont know but what difference would that make as it is still bleeding of sorts,and where is all the air coming from with no obvious leeks:brickwall:
Hi I had problems bleeding rear brakes because the spring on the Pressure valve had rotted off, I held the lever open and bled the brakes using an pressure bleeder (nearly flat tyre @15lbs.) .It worked. I dont know about the air youre getting , mabye from the valve or master cylinder ?. always bleed the furthest away first.
Thanks for a quick reply.Spring is ok,will check valve end tommorow.Waiting for delivery of pressure bleeder.Will update thanks
(13-02-2012, 09:06 PM)To clockwork Wrote:  Thanks for a quick reply.Spring is ok,will check valve end tommorow.Waiting for delivery of pressure bleeder.Will update thanks
 Did the pressure bleeder sort the problem ?
Holy thread revival Batman! This was a post from 2012, and the person posting it has never returned to the site in 11 years, so unless they keep an eye on their email, I expect you won't hear back.
Today 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
