[Warning Light] ESP/ASR system faulty
Hi all…. I’ve had to change the Squibb on my 2017 berlingo van due to a faulty switch, all installed fine and plugged in however I now have the ESP/ASR system faulty…. Do I need to do something? Have I missed something? I put the old Squibb back in and still have the same issue?
The Squib on the airbag? Or the electrical connectors? What switch was faulty? You'll need to find the fault code. Also, changing this item may require you to tell the car it has been replaced and you will need the appropriate software to do this. Basic readers don't delve deeply enough and you'll need the Citroen software.
(14-12-2022, 07:53 AM)Vanneria Wrote:  The Squib on the airbag? You'll need to find the fault code. Also, changing this item may require you to tell the car it has been replaced and you will need the appropriate software to do this.
So with my code reader no codes have come up, I will run to the garage later and hopefully it’s just a coding issue
Rattling calipers
Last Post: Chrisfox1975
Today 08:09 AM
eolys
Last Post: magoo1
Yesterday 06:02 PM
Yet another ABS fault
13-05-2026 05:57 PM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
