Threads: 59
Thanks Received: 11 in 10 posts
Thanks Given: 49
Has anyone fitted a Citroen snow screen to their Berlingo and does it work to speed up warming up?
Or is there something else I can use?
Threads: 8
Thanks Given: 305
36
A snow screen (Radiator wind deflector) won't really make the engine reach operating temperature any faster if your thermostat is working as it should. That said, if the deflector reduces the amount of cold air circulating around the engine compartment this could possibly make a very slight difference but I doubt it.
A deflector will restrict / stop the flow of air through the radiator so once the thermostat opens the coolant passing through the radiator will not be cooled as much so the operating temperature of the engine should end up higher than normal, if you fit a deflector you need to monitor this carefully as you don't want the engine to overheat if you drive a little further than usual.
Threads: 75
Thanks Given: 223
164
14-12-2022, 11:07 AM
(This post was last modified: 14-12-2022, 11:08 AM by Sol.)
it takes me around 10 miles before I get full heat. After 5 miles the coolant temp is still 60-70 and very little heat is produced. As JJ says, the screen is not easily controlled from inside if it starts to overheat. Modern diesels are very efficient and cold runners unless working hard.
I do remember seeing a vehicle with a thermo controlled blind on the rad but I think it was a Merc or a Jag, not sure if that is something you can get aftermarket.
Threads: 75
Thanks Given: 223
164
Excellent! I might try the same thing then. Just till the cold snap is over of course.
• John Bilko
