Codes
My battery is pretty dead when its -10.
Will i have any problems with key fob and radiocode
If i remove it and put in a new one?
I remember volkswagens were problematic.
Its a 2009 b9 multispace.
(14-12-2022, 04:39 PM)Lingo09 Wrote:  My battery is pretty dead when its -10.
Its a 2009 B9 Multispace.
I've got a 2008 B9 Multispace and have had the battery out a good few times as I had a problem [that turned out to be the starter, not the battery] but I'm pretty sure I never had to put in any radio codes or had any problems with the key fob. Mind you I did follow the BSI shut down procedure but if you battery is completely discharged than I'm assuming everything will be shut down anyway.
The last Citroen I ever had to enter a radio code on was my ZX 1.9TD Estate.
Yesterday 05:50 PM
15-11-2026 05:06 PM
15-11-2026 04:54 PM
One thing after another
14-11-2026 10:56 AM
14-11-2026 08:44 AM
