Threads: 69
Thanks Received: 22 in 22 posts
Thanks Given: 7
4
Hi all ,can anyone shed some light (no pun)on my problem??? Where or what is the mechanism that controls the tilting of the headlamps on my 03 berlingo ?? The N/S headlamp is tilting half way up compared to the O/S headlight,or is this normal ,TIA Gwyn
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
It's normal for the nearside to be straight and dead ahead, where offside is down and left to not blind oncoming drivers. Best plan, go to an MOT station and get the alignment checked, costs £15 most places. I need to get mine done.
Adjusters are just various knobs on the back of each light but you're better getting it done on the beam machine.
Threads: 29
Thanks Given: 67
20
I'd check if the bulb is seated properly before I did anything else to it.
Threads: 75
Thanks Given: 223
164
19-12-2022, 10:00 AM
(This post was last modified: 19-12-2022, 10:02 AM by Sol.)
We all have that switch, but each headlight has horizontal and vertical adjustment knobs on the rear, that roller switch is a motor controller which tilts the inside of the lights up or down of course, so if one is wrong, it needs checked on the beam machine and manually adjusted. Then they will move correctly when you change the roller switch. It's intended use is when carrying a load in the rear and should be at the correct level when set to 0 if the boot is not loaded up with stuff..
At MOT time the tester normally always just adjusts your lights without mention of the issue.
Threads: 69
Thanks Given: 7
4
Ok cheers Scott much obliged to you ,and a merry xmas to you and the boss ,
Threads: 75
Thanks Given: 223
164
Haha I'll pass that on to her, and have a great Xmas too Gwyn, to you and the missus!
Threads: 13
Thanks Received: 32 in 24 posts
Thanks Given: 8
19-12-2022, 11:22 PM
(This post was last modified: 19-12-2022, 11:24 PM by Kyleonsite.)
The headlights are adjusted by IIRC an 8mm socket and extension from above the headlight unit. Can't remember exactly where it is but it's a white plastic hex - I've messed with mine.
One issue you might have is that whatever level adjusting mechanism is inside the headlight housing can go a little haywire and end up making a loud noise as it constantly searches for its position or gets stuck in the wrong position. It might be someone has previously unplugged it. I fixed mine by drilling a few holes in the housing and spraying in some electrical cleaner and WD40.
2004 Peugeot Escapade 2.0HDI. 115k miles
2004 Volvo V70 2.4 208k miles
2011 Volvo XC90 215k miles
2005 Porsche Cayenne 170k miles
Threads: 69
Thanks Given: 7
4
Ok cheers Kyle much obliged
