Gear issue
Ok first post.
Van won't change out of 4th gear, clutch is ok but seems that something has snapped, took off plastics to have a look the cable on the left is stiff and doesn't move at all. Other cable moves up and down. Is this the issue and is it and easy DIY job?
I assume that one cable moves the gearbox connection forward and back and the other moves it from side to side . If the gearstick needs to move backwards/backwards to neutral then I'd says the stuck cable is the cause.
Never saw one with cable driven selector or changed one so cant help you there.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Check the gearbox end to see if any of the bits have come off. There are a few levers on the engine end of those cables.
Here's a diagram of both ends from Catcar.info
Rear seat belt breakage
Last Post: Mad one
Today 06:09 PM
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
