Threads: 2
Hello ,
My 2010 Berlingo multispace has non functioning temp guage.
I have a suitable replacement sensor but just wanted to check on getting access
to the old sensor in the drivers mirror. There is a strip going all round the mirror
with the sensor in it. I tried prising this off with a flat headed screwdriver in the groove underneath
but nothing happened. I did check old posts but they just made it sound easy. Is it this narrow strip all round that needs to be prised off?
Best wishes to all,
Dave.
Threads: 46
Thanks Received: 159 in 129 posts
Thanks Given: 34
23
With 'dashes' [horizontal lines] in the display it will almost certainly be the sensor. The only other thing I need to add is that after you gain access to the sensor to replace it, you need to splice the new sensor in as it is hard wired in so you need to cut the wires on the old sensor and splice in in the new sensor, so make sure you leave enough wire length on the old wiring to give yourself easy access to splice in the new sensor, any excess wiring can just be coiled up inside the mirror housing. FYI it doesn't matter which way around you connect the wires as the sensor is a thermistor [a temperature sensitive resistor]
Threads: 2
02-01-2023, 02:52 PM
(This post was last modified: 02-01-2023, 02:53 PM by daveman.)
Hello Multispace,
As it wasn’t raining here I managed to get inside the driver’s mirror. The temperature sensor was replaced fairly easily by soldering it in and covering the wires with mains sleeving. The end of the base of the sensor had to be filed quite a bit for it to fit in as well as a slight nibble to a plastic rib on the moulding to get it to lie flat. It is very pleasing to have done this myself considering what the garage would have charged. I got the new sensor from a Citroen dealer for £55 but later saw some on Ebay for £10. Getting the sensor out involves opening a single clip and levering the plastic open a bit. Thank you so much.
