[Transmission] Dual mass flywheel or solid?
Good evening all. I'm thinking or replacing the clutch in my 2006 Multispace 1.6hdi just after Christmas. The more I read the more confused I am in regards to whether its a dmf or a solid flywheel. The majority of info on this forum suggests it's solid, motorfactors list dual mass based on the reg. Could someone please explain how I could check this without taking the gearbox out. Any help will be much appreciated, thanks.
Sent from my Pixel 5 using Tapatalk
My vehicle:
2006 Citroen Berlingo Multispace Desire 1.6HDI
If you PM me with your VIN or post your VIN here, I can take a look in ServiceBox and see what it says. It's not always 100% but it may help.
AFAIK the m59 diesels were all solid flywheel. (2.0 & 1.6 HDi)
I believe the first DMF was on the B9 110 hp engine.
  • Chips'n'gravy
(22-12-2022, 08:30 AM)cancunia Wrote:  If you PM me with your VIN or post your VIN here, I can take a look in ServiceBox and see what it says. It's not always 100% but it may help.
Brilliant, thank you. Will let you know this afternoon
My vehicle:
(22-12-2022, 09:33 AM)jj9 Wrote:  AFAIK the m59 diesels were all solid flywheel. (2.0 & 1.6 HDi)
I think you're right about that, I'll take a look later to see what ServiceBox says when the VIN arrives.
So, the VIN is: VF7GJ9HXC93413386
Thank you kindly!
My vehicle:
No promises but ....
From what I can tell it's a solid flywheel part number 0532N0.
As @jj9 noted above, it's almost certain to be the case.
Have a look on the parts in motion website and put your reg in there. If they send you the wrong thing, they can replace it for you..
https://www.partsinmotion.co.uk/?gclid=E...gLlwvD_BwE
Thank you Cancunia.
According to parts in motion it is a dmf, they list a conversion kit to solid.
My vehicle:
I will let you know when I rip my croaked engine out after Crimble.
230,000 miles,  (Resurrected at 186,000)
(22-12-2022, 10:37 PM)Chips\n'gravy Wrote:  Thank you Cancunia.
Interesting!
ServiceBox is not always correct, but then again, nor are the motor factors. One option is to give PiM a call and say that it may not be a DMF and would they replace whatever you buy from them FoC if they're wrong. There's a chance you'll loose a couple of days that way but if they agree, you'll at least be covered.
I suggested PiM as I've always had good service from them & reasonable prices.
Today 05:30 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
