Threads: 4
Thanks Received: 2 in 2 posts
Thanks Given: 2
Hi there, wash & wipe option in my Berlingo multispace 1.4 2001 forte doesen't work, the last time this happened I thought it was the pump and when it was being MOT it was a power problem and the garage replaced a fuse or fuse's. I checked my board inside the car and on the top row at the right hand side I found a 5 amp fuse gone so I replaced this but it still didn't work!
I moved the fuses about in the engine board and still no success, anyone out there with any idea how to fix this I would appreciate the input.
I have been on the owners forum with this and had feed back but I thought I'd check to see if anyone had had this problem and how it was fixed.
Thanks in advance
Threads: 8
Thanks Received: 31 in 26 posts
Thanks Given: 8
01-02-2011, 01:20 PM
(This post was last modified: 01-02-2011, 01:22 PM by shedpete.)
For me, replacing Fuse 14 (10A micro IIRC) in the under-bonnet fuse box fixed it. (2003 1.6 petrol)
Threads: 4
Thanks Given: 2
Cheers, I'll give it a try and feed back
Thanks again
Threads: 4
Thanks Given: 2
Hi there, well I thought I had repalced the blown 5amp fuse but it had actualy gone as well, tried replacing the 10amp fuses one at a time with no joy then my father got involved and suggested I checked the 5 amp fuse again and yes it was! but this time we fitted a 7.5 amp fuse and this worked. Was advised by a guy at work that some times the ratings are a bit close to the mark when a bigger fuse would work.
Getting serviced and a MOT this coming Friday so fingers crossed. There is a bush underneath that needs replaced as its knocking like H**l when I turn at rough corners or junctions.
I liken this forum
Threads: 147
Thanks Given: 263
11
Hi caravan, appreciate you getting back to us on that one. Glad you got it sorted and good luck with the MOT.
There is a checklist i can put up from Haynes if needed.
The following 1 user says Thank You to Andre for this post:1 user says Thank You to Andre for this post
• caravan72
Threads: 51
Thanks Received: 35 in 32 posts
Thanks Given: 3
there prone to going so. my 5 amp went too but is working since i replaced
Threads: 4
Thanks Given: 2
Hi there, well it only needed a ball joint to pass and my father fitted a pump and bottle to the back of a head light and connected the existng wires and pipes to it and hey presto! it worked. It only feeds the front screen, you don't need working wipers or wash for the back window for the MOT.
It now needs the timing belt replaced another 3 figure job!
