Threads: 3
Thanks Given: 8
Probably because of the freeze and me trying to use the washers but now not working. Cannot see where pipes go. Any thoughts or should I take it to the garage?
Threads: 6
Thanks Received: 2 in 2 posts
Thanks Given: 6
Happened to me a week ago, I'd blown the fuse (10amp), it's located under the bonnet passenger side No-3 in the fuse box, quite a few have had the same problem this year.
Hope that's your problem it's an easy fix.
Threads: 75
Thanks Given: 223
164
27-12-2022, 10:00 AM
(This post was last modified: 27-12-2022, 10:01 AM by Sol.)
The pump is mounted on the water bottle, deep down in the drivers side arch, ahead of the wheel well (i.e. behind the bumper area)
It could have gone if the fuse is not the issue. Many people have the problem and it's not the fuse, been there myself.
• Jeffree
Threads: 3
Thanks Given: 8
Ok got the wrong fuse box. Didn’t know there were 2
Threads: 75
Thanks Given: 223
164
28-12-2022, 09:03 AM
(This post was last modified: 28-12-2022, 09:04 AM by Sol.)
Threads: 75
Thanks Given: 223
164
That's an aftermarket fuse if it's a shot of your fusebox. Some do look different. Question is, has it blown or not.
• Jeffree
Threads: 3
Thanks Given: 8
Thank you everyone. I imagine it was replaced before. As the fuse looked very different to the rest. I replaced it with one of the spare 10amp and now the washers are back to working order.
