  • 4 Vote(s) - 2.5 Average
water pump/timing/fuel pump
if i have turned my 2000 x reg van over with the water pump froze
would it knock the timing out therfor not turning my fuel pump
therfor not puttin fuel into my injectors thats why it wont start?
thanks jamie
(14-02-2012, 09:05 PM)shaw1644 Wrote:  if i have turned my 2000 x reg van over with the water pump froze
thanks jamie
Hi , It is possible that if the water pump was frozen solid, the resistance on the cambelt could cause it to either rip the teeth off at the bottom pulley, which woud not be good, or if you had a good belt it would turn the water pump round and perhaps make the impeler inside spin, some are plastic. best thing to do is take the top cover off the cambelt housing and have a look and see if its tight, perhap turn the engine over by hand on the crankshaft pulley, good luck.:wave:
[-] The following 1 user says Thank You to bechstein for this post:
  • shaw1644
sorted the van as i had taken off the anti tamper and cut the imobileser out, i had turned the fueling screw after messing with this and a bit of easy start it fired !!
thanks for your help lads
MOT Emissions repeated fail
Yesterday 05:05 PM
Rear door filling with water
Last Post: Marsaday
Yesterday 04:37 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
